You need to enable threaded optimization and triple buffering
Maybe I know the problem: could it be a problem that the only 9% of the gpuâs video decoder is used, while riding in Zwift?
And I dont understand this: Every time I change the resolution in Zwift from 4k to full hd the gpu is only used by 40% and I only get about 60fps to 70fps. Why doesnt it produce more?
Zwift is CPU-limited. Thatâs whatâs limiting your frame rate.
I would definitely try Paulâs suggestion above in turning off spring camera and see if that helps.
Ok thanks.
Yes I did it today and the stuttering was still there.
ah thatâs a shame - i had similar (although more pronounced zooming in and out rather than stuttering) and it fixed it for me
I think the time has come to ask the Zwift support. Yes?
Have you changed the settings i suggested?
Yes I already had them on.
Ah ok. I didnât watch all the video but they werenât on when i first saw the settings.
Edit.
Just watched again and they are not set to on. Auto is not the same as on.
Both were on Ein = On?
By the way now I am going to buy the i3-12100F. I hope that this will solve the problem.
