I was having a lot of issues with my computrainer not being found on the pairing screen. After trying to use RacerMate to turn it on, it eventually stopped.
Thanks to co-pilot, I was able to figure out why Zwift could not locate any COM ports. It turns out that the pairing screen appears to be looking for Bluetooth devices ONLY and not COM ports.
To fix that you will have to edit your prefs.xml file found in My Documents.
Make sure Zwift window is closed.
Right click on the prefs.xml file and Open with Notepad.
Scroll down and add the following line after < ZWIFT >
<USE_SERIAL_PORTS>true</USE_SERIAL_PORTS>
So it will look like this:
What this does is that it tells Zwift to turn on old Windows serial-device pairing screen. It should be able to pick up the Computrainer and other wired trainers (if they exist).
Save. Then reload Zwift. Your computrainer should load very quickly in the pairing screen.
Please let me know if this worked for you! I hope this helps!
