I am looking for help on adding my zwift power id number to my zwift profile after the username.
I have zwiftpower and have done some racing but I do not know my id number?
When I try to log in to zwift power I can not, I have them reset my password and I use the link, it says successful but then I see no “could not find profile”?
Is the profile in zwift power something I should see and get my number to add to zwift?
I am not sure the password reset link logged me in even though it indicates successful.
I go up and enter username again and try the password they sent and it fails?
Then contact system admin says off line.
I was hoping to add this number for future events and races.
Will my entry still work without adding the number?
Thanks, I now have my number and will add it.
I will work on the log in issue later.
Are most people adding their numbers and is mandatory to have the number or just zwift power?
I have raced prior without it but after reading the latest challenge flyer I thought maybe it was going to be required.
No one will doubt my 3 watts per now!
Rob
@Gerrie_Delport can answer that better than I can.
You only need to add the number for one event on Zwift so that Zp can connect with you.
Is it a 4 digit number or 6.
I see 132966 when I look at the file.
I generated the 4 digit and will add it.
If people would just read the directions damn it!
Sorry I must have essential Virus fatigue (I just made that up)
Still failing, it gave me different user to connect to so I must not have the correct user id 132966
Rob Mitchell
Hi Rob, Your user id should start with 159XXXX
7 numbers
Log into https://my.zwift.com/,
Go to one of your rides click the gear icon and when you hover over Download you will see your ID in the bottom
OK,
Thanks for your time.
Now I changed to full screen (■■■■ everyone knows that) and see it, 1593996. I had a smaller window on my monitor and the number did not display.
Only download and select a reader format. Wow I suck and have Essential (expendable) Virus fatigue , I just made that up so it is now a real thing from when you are working but don’t get the essential feeling.
I am added and signed the waiver to the power site and no one will doubt my average over the hill numbers. Thanks again.
I owe you a pint.
Rob
