Zwift play stuck many different ways
I got my zwift play mid-february.
Right from the beginning, I had:
very often left controller stuck on steering left
a few times left controller stuck on downshifting
but I had also some sessions where everything was fine
in the last 2 weeks or more, I ALWAYS have
left controller stuck on braking AND right controller stuck on shaking as soon as I shift.
actually last 2 days left controller was stuck on braking AND steering left (ok no effect since I couldn’t move…) AND right controller stuck on shaking.
checked firmware, seems to be updated
tried reset a few time (why there’s no feedback on that?)
thank you for help
Probably damaged by sweat ingress. Contact Zwift support through the website or at support@zwift.com
ok thks.
please note it started a couple of days in.
Hi @Paolo_delma_Delmastr
Thank you for reaching out to the Forums! This is Haziel from Zwift. I really appreciate your issues with your Zwift controllers.
It’s great to hear that you’ve already verified your firmware is up-to-date and have tried resetting it. To help you resolve this, let’s take a closer look at a couple of things. It’s essential to ensure that both controllers are calibrated. I also recommend following the steps outlined to Connect Your Zwift Play​​.
When you have a moment, please try unpairing the controllers and then pairing them again one at a time. This can really help ensure that each controller pairs successfully. Also, make sure the batteries are fully charged at 100%. Once everything is paired correctly, you can connect your trainer.
I hope this information is helpful, and if you have any more questions, please don’t hesitate to contact us
thank you very much.
tomorrow I’m doing as you say.
reading from another post that he didn’t have problems when controllers in charge I tried that, but nothing changed.
did calibration.
right controller no vibration
left controller vibration only on right
no auto restart
done several more times with always diffferent results (1 click - 2 clicks, 1 and 1, 2 and 1…) sometimes one controller restarting … never fully working
Sounds like you need to contact support and talk about replacement
