I have had zwift play for a few months now. I have used it without much trouble since now. My wife recently started zwifting too, using her bike. We use a zwift hub, which is zwift play compatible. For some reason, we cannot shift up anymore, despite the stearing and other buttons working. I must conclude that the button has a problem, is there any way to return this to get them exchanged / fixed?
can you share, what you have done to reset? I have a similiar problem with my Play controllers, it happens mostly after doing a workout and i have to switch off and on virtual shifting to get it working again.
Hi @Matthias_Hivner Welcome to the forums. This is Juan, a Zwift colleague. Sorry to hear that your Zwift Play is not performing as expected. Your controller should go to sleep 3 minutes after being disconnected from the game and after 25 minutes it should fully turn off.
If that is not the case, please try gently pressing and holding the big Z button for 30 secs on the affected controllers, this should restart the unit completely. If the issue persists, a calibration could fix the connection issue. Anyhow, I encourage you to contact us at support.zwift.com . There, we will be able to provide you a detailed guide on how to do it.
