Zwift play - gearing
Good morning,
I connected my Zwift Play paddles with my Wahoo KICKR CORE including cassette and my device (I-Pad).
All is working well, apart from gearing.
My questions:
The intense side buttons (24 gears) are not working.
Anything I forgot?
thx
Andy
Is the firmare on your trainer up to date, and is virtual shifting turned on in the Zwift settings? And is the trainer paired over Bluetooth and not ANT+ ?
Can’t be ANT+ since the device is an iPad, so firmware updates to the Play and trainer may be needed, plus enabling the setting if it’s disabled.
Good morning guys,
thanks for the prompt replies. I do generally update the firmware, as the Zwift app usually informs me to update. I don’t think, that I have to update anything on the Wahoo Trainer, do I? All connected via Bluetooth, correct.
I believe, I have to activate the virtual shifting. (hope so)
This would make things easy.
How and where do I activate this?
You should ensure that the trainer firmware is 1.5.36. If the firmware is too old, virtual shifting will not appear in Zwift settings.
perfect Paul, thanks a lot. Will try this
all works well now, perfect and thanks!!
