Hi Zwifters,
I did the Mountain Massif TT event and Strava shows the following profile. Distance is correct, meters of climbing is off by 188m and the profile is completely wrong (some parts at 35% incline and so on)
Hi Zwifters,
Did you use the “correct elevation” option within the activity’s menu by any chance?
Might be worth selecting the option again in case it’ll go back to the original exported file’s elevation data - I presume it all looks ok on the companion app (in terms of elevation)?
Thanks for the advice! The companion app shows the correct data (and thanks to you strava does now too
