Zwift not start with iMac Version 26.3
I can’t start Zwift with iMac with Version OS 26.3.
Its freezing after first login steps… check the picture.
I have Zwift and Software updatet today, but nothing better then before.
Any Ideas what I can do ?
Have you tried going through this process?
Hi @Patrick_Molinari welcome back to Zwift forums.
Shuji at Zwift HQ here. Looking through your server logs - I see you have logged in from three different Macs and an iPhone in recent days. It looks like your iMac is the one that’s freezing, is that right?
Try the complete uninstall & reinstall procedure that Paul suggested. Doing that will also download the latest Zwift Launcher v 1.1.15. Would you verify if that solves the freeze during game initialization?
Also: since you have more than one Apple device: Apple released OS 26.3 earlier this week. You should be aware that OS updates reset Bluetooth and Local Network Device permissions to the default “No” settings. This means Macs / iPhones / iPads / AppleTVs won’t see your trainer’s Bluetooth signals in the Zwift Pairing Screen until you reallow permissions. The simplest way to do that is to re-install Zwift and say Yes to all the permission requests.
Would you let us know if re-installing clears this up for you? TIA.
Thank you for your help, Paul. I deleted Zwift this morning and reinstalled it, but not using instructions like the ones you linked. I’ll try those. Thanks again for your help.
Hi Shuji, thank you very much for your reply. You’re right, it’s the iMac that isn’t working. But I updated my MacBook Pro to OS 26.3 today and it’s working perfectly—no Bluetooth problems either.
However, I noticed that all my folders are synced via iCloud. That’s why I’m hesitating to do a complete reinstallation of Zwift, because it works without any problems on my two MacBook Pros. I only use the iMac as a backup.
I know that might not sound logical to you, but I have to admit I’m not an IT specialist, and a full reinstallation doesn’t seem simple or logical to me. Maybe there’s another solution that will get the iMac working again.
@Patrick_Molinari
Please follow the official instructions in Paul’s link. This is a more complete uninstallation procedure that may help you with your issue.
After installing OS26.3 Zwift doesn´t find my Wahoo Kickr Core or my Polar H10. I tried to reinstall Zwift according to your instructions. When starting Zwift there are no permission requests and Zwift still can´t find my devices. What should I do?
The macOS 26.4 is now out. Has anyone tested, if the Zwift will work with the latest version?
Upgraded my macbook to macOS 26.4 and launched the Zwift application after that: I did not notice any issues. When the app is launched for the first time, the macOS asks if the app should be allowed to access its folder and if the app can search for wireless devices. After that everything worked normally.
Apologies, but yes as you found it does work. I’m also on 26.5 developer beta and that’s running fine as well with M4 Pro Mac Mini and a 2019 Mac Pro (Intel Xeon W3275M and Radeon Pro W6800X).
