Dear zwift community,
I recently bought the zwift bike frame … and I am supper excited to start cycling again.
However, I am having issues with the set-up…
I have the zwift hub since 2022, and I found it easy to install my road bike frame on it.
However, I am not able to put my new zwift bike frame correctly. Can someone please help me and explain me in layman terms - I am very bad at mechanics etc
- please explain which items go on which side (left / right) and in which order. See attached a picture with the pieces that I have.
Thanks in advance, it would be very helpful!!
Ps I reached out to zwift support, but it didn’t work. Their suggested solution included: “step 2 - remove the rear wheel from your zwift bike frame”
( no kidding)
It looks like you don’t have the Zwift Cog fully installed on the trainer. See the guide linked below. Once that is done, you need to screw the silver thru-axle adapter onto the right side of the trainer. The black/green adapter slides into the left side of the trainer. The Ride frame is a 142mm thru-axle design which means the green part of the adapter should not be visible once installed - that should be the side that goes into the trainer.
( no kidding)
Solved: apparently you don’t need anything, just the thru axle and you need to tighten it well.
Thanks Paul.
So I just did this. It seems to work fine - green/black on the left. And now I connected the cog fully (added the wide metal piece before connecting the cog).
However, when I stop pedaling, and pedal backwards, the chain falls off. Am I missing anything.
Is the Cog rubbing on the frame?
Or is the chainring on the bike bent?
