Zwift ride smart frame
I currently have the Zwift hub one and i want to purchase the smart frame.
will I need to put the Zwift cog upgrade on the trainer or can i still use the original one
I’m keen to get my moneys worth out of the original, then swap it when its worn?
There’s been a recent report from someone using it with the older Cog successfully. The main difference would be ability to adjust chain line with the newer version.
Hi @Rob_H2, thank you for bringing your concerns to the forums!
I’m Fernanda, from Zwift.
I wil like to put my two cents on your concern, and let you know that you can successfully use the original Zwift Cog of your Zwift Hub One and mount your Zwift Ride frame only in it, just remember, if you are currently using a quick release on your Zwift Cog, remove the Quick release adapter (pink one), since the Zwift Ride uses a Thru Axle system, you will need to switch to your Thru Axle adapters on the Drive Side (silver) and Non-Drive Side (green one) of the trainer.
If you missed any of the adapters, don’t need to worry! Remember that you can reach out to us and we can provide you with the original adapters of the Zwift Hub!
To get visual guidance, you can check the process here, to mount the Zwift Ride in the original Zwift Cog v1 (classic version) and this video!
Keep us posted.
Thanks for the reply :+1:
