Zwift Hub One needs TWO Click remotes for triathlon bikes
Can Zwift please allow us to buy an extra Click remote and allow two to be paired at once to the game? If you ride a tri bike, only one shifter is a huge downgrade to use. It’s in the wrong place half the time and you have to reach awkwardly to shift. It’s just a small and cheap remote that would make a HUGE impact in ride experience. We can’t use the Play remotes because they don’t fit our bars. I tried pairing two Click remote shifters and the game won’t let you, even if you owned two. Please modify the game to allow to pair 2 of the Clicks at once and allow for the purchase of additional Click remotes individually on your site. Thanks.
Where would you put the 2nd one?
I assume you’d like one for the tri-bars and another around the brakes?
That was my thought. Some TT/tri bikes with electronic shifting have a second set of buttons on the base bars, but those of us with mechanical group sets manage with just the shifters on the aero bars.
Yep dual gear changing is commonplace with Di2 but obviously not with mechanical.
On Zwift i guess technically there is less requirement to come out of the aero position as you don’t need to brake.
If it’s a hilly route then I guess you would or for sprinting.
Just in case yall haven’t seen it - you can now buy extra clicks! I have a click alongside my play controllers that I keep on my tri bars.
I have a Cervelo P5 with Magura RT8 TT brakes and also hacked together di2 shifting for the base bars - and a lot neater than Garmin Sharp did with theirs.
@Teddy_Svoronos @Brett_Zwifty
Hi there - please note that only one Click shifter button can be paired to Zwift at once.
While the Click is available as a standalone purchase - this is intended for for people whose trainer hardware can be upgraded to support Virtual Shifting with a firmware update. At the time of this writing, we’re talking about several Wahoo KICKR models and the KICKR Bike. See the current list of trainers that support Virtual Shifting here.
Thanks Shuji! Though in my experience I can pair both controllers and a click, right?
Hi @Teddy_Svoronos, I’m Gian from Zwift.
Yes, you can pair your Zwift Play and Zwift Click at the same time. Shuji’s note is to clarify that while you can buy a standalone Zwift Click, you cannot pair more than one Zwift Click. However, using the Zwift Play and a Zwift Click simultaneously is fine.
Ride On.
