Zwift Game v1.33 Major Issues Update [January 2023]
Theres a growing raft of people having connectivity issues with devices no longer pairing albeit they seem to be more BT related.
Yep:
Restart/re-install on ATV and companion app Didn’t work for me to solve the stalled drops issue. Thanks for the tip anyway.
I do have connectivity problems after firmware update. NO SIGNAL when pairing to zwift hub soon after initial connection ok. Connection to other smart trainers listed in the app works surprisongly, but shows wrong pace etc. Seems like a software problem, doesnt it.
Bitte entschuldigen Sie mein Deutsch. Wir sind dabei, Patches herauszugeben, um Probleme zu beheben, die in der ursprünglichen Version entdeckt wurden. Der erste veröffentlichte Patch behebt den Mangel an Widerstand im ERG-Modus. Nachfolgende Patches und Versionen werden andere gemeldete Probleme beheben.
+1. Treadmill BTLE is definitely broken for iOS in last release. Worked fine last week. (Can confirm as well that TVOS works.)
Yesterday i installed Zwift 1.33.1 on my Android phone (for the first time), and i could not create a BT connection exactly like the problem in my iPad.
So i continue the troubleshooting and download the PC windows version to my Lenovo Laptop and i was able to create a BT connection.
So:
  1. My Spinning bike is not the problem.
  2. iOS & Android are having a BT connectivity issue with their last version.
  3. A temporary workaround is to use the laptop with Windows until new releases
i have a video that clearly show the connectivity issues
They are working on it. Thanks for your response
I have exact these Problems, and they still occured yesterda night 30.01. on road to sky:
  1. resistance and gearing is totally off, it seems i have an automatic bike (on flt roads i runout of gears,
    but then on the other hand can stay in very heavy gears up to road to sky)
  2. screen often show s “connection lost” on top… but that has no influence
  3. to start and load takes almost 3 times as long as it did before
  4. also the companion app loads may slower
thanks
stefan
Hi @Stefan_Glaser
Welcome to the forum.
Did you check your trainer difficulty setting.
Can you post a screenshot of your pairing screen?
Same for me, since the last update. Zwift need to sort this asap
drops not accumulating properly. it seems to freeze unless I hit a certain grade
Yeah - I’m stuck at 55.9 million drops… I was saving up to buy more donuts :doughnut:
Should be fixed in the next couple of days all being well.
My wahoo Kickr v6 is not being recognized by Wi-Fi/direct connect in the Zwift app on MacOS even after reinstalling Zwift.
I was able to connect with Bluetooth, but resistance still was not changing with grade changes while connecting via Bluetooth. Drops were accumulating for me. I did not try erg mode.
I have the same issue with my True 300 Treadmill. I reported this issue to Zwift Friday afternoon and was allegedly the first person to report a treadmill issue. Anyway, it has been elevated to Tier 2 and I received a follow up email Monday afternoon, where I was asked to uninstall and reinstall the app and report back. I did (even though I had already tried that route) and reported back yesterday (Tuesday) morning. Since then, no further updates or questions from Tier 2.
I have only updated Zwift on my iPhone. After it wouldn’t pair with my treadmill, I did not update my iPad, so at least I can still use it while I run. (Unfortunately, my husband updated both his iPhone and iPad and neither can pair with the treadmill).
Good news:
Since typing my first reply, I have received an email from Zwift support stating the following:
“After reviewing this case again, I went deeper and realized we are currently facing a known issue where treadmills are not pairing, and not appearing in the pairing screen.
I am sorry for any inconvenience this has caused you. We are currently working to get this sorted out. It has been fixed in 1.33.2, which will release soon.”
Hope that helps everyone.
What is the likelihood of those of us crashing to desktop in any Urukazi route doing the same in Scotland? I’m under the assumption that the same process was used to generate the Scotland routes. Mea culpa if this is not the case.
I can report back that the BT problem was fixed !!!
Been having issues with resistance. 4K Apple TV Wahoo kicker 5. I upgraded from kicker 17 to the 5 and since I’ve had terrible issues with high resistance low power. When riding up a low gradient resistance is added but does not drop it feels like it is adding resistance each time so 1% to 0% remains at 1% add 2% feels like 3% so on and so forth. Resistance at higher grades appears more normal and lightens on decent if it is steep enough. Maintaining a cadence of 80 is very difficult and watts appear not to reflect the effort. I can maintain the same watts/resistance on some descents as on the accents. Some decents appear to have higher drag than any climb. All devices are up to date, Zwift up to date. Wahoo app works as expected. Zwift as is, is risking injuries. If I need to use something else then it will be permanent. Sick of having to miss or have sessions because of broken updates.
