I’ve been having low fps issues for a while with zwift. Can’t remember when it started but current laptop set up was used for ages with no problem.
I ran zwift with the task manager open on the processes tab on the second screen so I could see what was going on. The CPU is bit being over loaded and the ram is running at about 80% but the GPU is being strange. It runs at about 60% and zwift runs perfectly but every few mins the GPU drops to 7% and zwift fps rate goes through the floor, maybe 3 or 4 fps… It doesn’t always come back and the GPU can be at 7% for a long time. When it does come back, it only last a few mins and then bad again…
Any ideas what could be causing the GPU to kick in and out.
It’s an amd radeon vega 8 graphics…
Any ideas would he great
