Hi @Pedro_Custodio, I sounds like something is interfering with your signal. I used a wahoo blue SC for a year with windows 10, and while it certainly had issues, I was able to make it work most of the time. Try switching to ant+, it is also supported by the wahoo sensors. You will need a ant+ dongle and extension cable, but it works much better.
Eloy ya lo he solucionado, cuĂĄndo vayas a conectar los sensores a zwift, gira Ășnicamente la rueda trasera para que se active el sensor de velocidad a la app d zwift y luego haz lo mismo girando Ășnicamente el pedal para q se active el sensor de cadencia (por separado, primero uno y despuĂ©s el otro, si no detecta las dos cosas a la vez y no funciona).
parece una tonterĂa pero a mi me funciona.
I have received an ANT+ dongle with an extension cable this week and it works fine now.
Regarding Bluetooth, it seems the Android App had difficulty synchronizing with the two sensors, cadence and speed, as they are separate.
Kind regards
Pedro CustĂłdio
-------- Mensagem original --------
Boas
Esse sensor usa no Android ou com PC?
Boas,
O sensor ANT+ liga ao desktop.
Cumprimentos
Pedro CustĂłdio
Enviado a partir do meu smartphone Samsung Galaxy.
Pois eu no PC n tenho problema usando o companion⊠Mas usando no tablet android se usar o sensor velocidade desliga o de cadĂȘncia. Usando cadĂȘncia desliga o velocidadeâŠ
So Swift dropped all ANT devises and did not tell us? Now I have to upgrade all my Wahoo sensors to a BLE Wahoo sensor to make Swift work?
Does Zwift not get along with Wahoo at a corporate level?
Bad communication of Zwift
I donât understand, Zwift work with out issue wit ANT+
You may have to roll back the kickr firmware.
It only supports Wahoo BLE devices not the old Wahoo sensors that just work on ANT. Correct?
I have a â dumb â trainer so I use the wahoo sensors to connect
Also wonder why my response today (Sept 2021) says i responded 2 months ago in April 2020?
No, Zwift didnât stop allowing ANT+ sensors from connecting.
What is the issue you are having? Have you tried connecting to any other app, or check the battery in the sensor?
