Joined Zwift yesterday. Running Windows 10 with 16gb RAM. The program seems very buggy, isn’t very smooth and crashes when trying to save each of my workouts the past two days. Not very happy during this trial/
Please post the full specs of your PC and which version number of Windows 10 you are on.
System Information
Time of this report: 3/14/2019, 19:43:15
Machine name: DESKTOP-1I1JRBT
Machine Id: Unknown
Operating System: Windows 10 Pro 64-bit (10.0, Build 17763) (17763.rs5_release.180914-1434)
Language: English (Regional Setting: English)
System Manufacturer: Microsoft Corporation
System Model: Surface Pro 4
BIOS: 108.2318.769 (type: UEFI)
Processor: Intel(R) Core(TM) i7-6650U CPU @ 2.20GHz (4 CPUs), ~2.2GHz
Memory: 16384MB RAM
Available OS Memory: 16310MB RAM
Page File: 4471MB used, 14781MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 168 DPI (175 percent)
System DPI Setting: 192 DPI (200 percent)
DWM DPI Scaling: UnKnown
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.17763.0001 32bit Unicode
DxDiag Previously: Crashed in system information (stage 4). Re-running DxDiag with “dontskip” command line parameter or choosing not to bypass information gathering when prompted might result in DxDiag successfully obtaining this information
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) Iris(R) Graphics 540
Manufacturer: Intel Corporation
Chip type: Intel(R) Iris(R) Graphics Family
DAC type: Internal
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_8086&DEV_1926&SUBSYS_00151414&REV_0A
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 4095 MB
Dedicated Memory: 128 MB
Shared Memory: 3967 MB
Current Mode: 2736 x 1824 (32 bit) (59Hz)
Are you running Zwift in full screen or Windowed Mode?
What graphic setting are you using within
Just an FYI the program closes when saving rides/runs.
I’ve tried both with the same result, when I click “End Ride” the ride’s summary screen minimizes then Windows says “(Not Responding” and is frozen for 60 seconds or so then crashes/closes.
What do you mean by “graphic setting”?
When in Zwift go to Settings and what do you have the resolution set to?
Also, do this work around to see if it improves the closing of Zwift when you are saving: [Workaround] Zwift not saving rides/creating folders
I am a firm believer that if you are running Windows 10 that you should also be running an SSD.
