I decided to open a new topic to split my experiences from another topic (“Heart rate monitor not connecting [November 2023]”)
My problem was that I couldn’t connect a “Garmin HRM Dual” (Bluetooth and ANT+ HR sensor) to Zwift Hub Classic for retransmission to the Zwift app. It worked in 2022, but when I tried to pair the HRM to Zwift Hub via ANT+ or BT since autumn in 2023, I didn’t work.
When I tried to pair the HRM with ZC app on an iPad yesterday, the HRM was immediately found and connected to my Zwift Hub without any problems and shows up in Zwift App on Windows 11.
After some more tests I found out (March 2024):
If I use Zwift Companion App (ZC) - Version 3.55.0 (1651) on an iPad, my HRM is recognized by the Zwift Hub after a few seconds and shown as connected.
If I use ZC - Version 3.55.0 (1750) on an Android Phone (Poco X3 Pro - not rooted, no alternative firmware, just original), the HRM isn’t shown as connected. Searching for an HRM doesn’t find it either.
In Zwift app on Windows 11 the HRM is available as a sensor (HRM via Zwift Hub) and delivers the correct HR, so it is paired with the Zwift Hub obvously.
The problem seems to be in communication between ZC on Android and the Zwift Hub while communication between ZC on iOS and the Zwift Hub seems to work as expected. I deleted all personal data of the Android app (didn’t work), uninstalled ZC app and reinstalled it (didn’t work either).
If someone at Zwift is interested in investigating this issue, I’m ready to help.
Did you get anywhere with the problem of pairing your HRM to the Zwift Hub using the Android companion app?
I have submitted a couple of support tickets over the last 6 months and got nothing but bot generated generic “help” directing me to the Zwift pairing procedure.
I can pair anything I like to my Apple TV but it runs out of Bluetooth connections. I can pair as many things as I like via the Android companion app but this has way too many data dropouts to be a useable solution. As a workaround I have ended up swapping the Zwift cog for a regular cassette and using this for anything where ERG mode is not applicable.
after it worked with the Apple app, I didn’t search longer for another solution. My HRM is still paired to the Zwift Hub and the Zwift Hub transfers the HR (received via ANT+) by Bluetooth to a Windows 11 PC.
I never got a reaction from Zwift but I didn’t open a ticket or a support case, so I can’t expect a reaction from Zwift. For now, I paused Zwift as every summer and I will be back in September or October.
Hi there, just want to say that I’m still facing the same issue here.
Apparently, no update has been done to the Android ZC app yet.
As stated earlier, a connection or disconnection with the Android app was not possible. I tried my wife’s Apple iPhone and it worked right away. If you are facing the same issue, please try using the Apple ZC app in order to make it work
I attached two pictures, one from Android and one from Apple, and you can immediately see the difference.
I reported this issue to Zwift Support on 29.12.2025, but since the Zwift Hub is not used by many anymore, I doubt that there are going to be any changes soon.
I have the exact same issue.
I have a Zwift Hub, a dual-band Garmin HRM, and an Android phone. Zwift Companion cannot find my Garmin HRM and so I cannot pair it directly to the Zwift Hub.
It’s bad because the Bluetooth connection to the PC where Zwift is running is quite unstable.
I’m having the same issue. This is truly garbage on Zwift’s part. Seriously, just fix the companion app! What the hell? I guess I can borrow one of my parent’s phone, but that will require going and getting it, installing companion on it, going back to my place, logging into the companion app on it, connecting the HRM, and then uninstalling the app and bringing it back to my parents. Why should I have to do all this when all Zwift has to do is UNBREAK the android app (it worked in the past, presumably on an earlier version)? Come on Zwift, I’m paying $20 a month for the app and the Hub was $500. The least you could do is have the features I pay for work.
