My Zwift Companion app routinely drops out of the ride I’m participating in and goes back to the Home Screen.
Occasionally it returns back to the ride (showing ride tabs, map).
In addition to this issue the map was displayed on my iPhone but I was unable to see my or anyone’s location on the iPhone screen.
Usually because your phone is intermittently using mobile data, which is enough to make the Companion app believe it’s not on the same network. Consider using flight mode, or just disabling mobile data during your ride. Alternatively you can disable network switching, which is called Wi-Fi Assist on iOS.
Greetings
I placed my phone in Airplane mode but left the WiFi on (not sure if that’s correct). The Zwift Companion dropped out at 30 minutes and after waiting several minutes I took the phone out of Airplane Mode and the map & dashboard returned.
I’m not sure if I misunderstood your original email.
Do I leave in Airplane mode w/only Bluetooth On?
Do I leave in Airplane Mode w/only WiFI On?
Or Airplane Mode w/both WiFi and Bluetooth on?
Kind Regards
Bluetooth shouldn’t matter on or off, that’s not used for internet traffic.
I would try just disabling Wi-Fi Assist. And ensure your phone isn’t jumping between different Wi-Fi networks at home. They need to be the same as the device you’re running Zwift itself on. Sometimes mesh networks are an issue.
Greetings
I will disable the feature.
I only have one network at home and all devices are on it.
Kind Regards
TF
Just enabling flight mode should have been sufficient to disable mobile data, so I’m not sure why that still dropped out. But give it a go without Wi-Fi Assist and see if it’s any better.
Hi there, I have only recently started having problems with my iOS device as my companion app, (which had been my reliable working companion app for the last 18 months) my iPad now only briefly connects at the launch of Zwift on my PC then drops out but when I use my android device it connects without any issues every time.
I have a mesh setup so I don’t think I can differentiate between the 2.4 or 5 ghz bands?
Would you have any ideas on a solution, the iPad is a much bigger screen so I find it more convenient to look at with messaging etc and it is only on wifi so it’s not trying to connect on a mobile network.
I’ve found no consistent pattern. Leaving WiFi on has been essential for the companion app to link to Zwift activity. Other than that conclusion I’ve given up on science & technology and will be consulting with my local Vodoo Witch Doctor. Possible an exorcism.
But seriously how hard can this be to get fixed.
Companion App was working fine for me acouple of weeks ago… It now only works on my Iphone… on the Ipad it flicks up at the start and disappears. Companion app turned off on all other devices, I’ve restarted the router, even reset it. Wiped the ipad after trying a reinstall of the app. Firewall open on the PC… Flight mode on, changed channels on wifi, tried 2.4 & 5ghz. No joy…
App version on both Iphone & Ipad 3.30.0 (1172) Server version 1.26.1… PC Ethernet both on the same subnet
