Zwift cog issue
Got a new tacx neo 2t this time with the zwift cog, thought I needed the XDR adapter but google says no. Try to mount bike, not my fav thing to do (why does something always go wrong) chain on, but for the life of me the non drive side was way too close to the frame, after 30 mins I give up the will to live and put the wheel back on
I know one of the metal pins was bent,I fixed it,and it went on better but obvs something doesn’t fit. Ive been on zwift since 2021 but always used a proper cassete
Have you gone through the setup guide appropriate for your bike? I’m not sure which axle type your bike has so it’s hard to make specific recommendations.
I wouldn’t expect to use an XDR adapter with a Shimano freehub, which is what the Cog is mounted on. There is no XDR version of the Cog. But that doesn’t answer the question of which adapters you should be using because I don’t know anything about the bike.
I thought I needed the XDR adaptar but that is only with a casette, so mounted it on the zwift cog as it comes, just tried to remove and reinstall, one of the small metal bits is broken and inside of the hub on the trainer (before it was just loose) so that’s not ideal, but the same kind of gap
Normal road bike axels, nothing unusual, all worked with a normal cassette on another trainer in the past
If you have a new trainer and part of it is broken, you should talk to either the manufacturer or the retailer about that.
If you shared details about the rear axle format of your bike it might be possible to suggest some info about the adapters, but I think you’re better off engaging with someone responsible for the product you just paid a lot of money for and adding on any other questions you have about setup after you’ve discussed the damage.
You don’t know the normal size for a rear axle? 12x142, thought everyone knew?
That depends on the type of frame you are using. 12x142 is a very common thru-axle format for modern road bikes, but people use a wide variety of bikes on trainers that are not 12x142.
Yeah I know, just odd you didn’t and go on about needing that info, if the bike is too close to the trainer the axel doesn’t matter even
Sounds like one or more broken freehub pawls. As the OP says this is “inside the hub” I wonder if this is creating an obstruction and preventing the Cog freehub from sitting far enough into the trainer.
Yes this is why I think contacting support or the retailer is the best option in this case. Nobody should tolerate buying a really nice new trainer and it arriving in broken condition.
one of the silver things came out (is that a pawl?) but it still doesn’t seem to sit flush enough, not tried the bike yet
This might explain the sort of parts you are dealing with and whether or not you are missing any:
Freehub workings
I’m guessing nothing is supposed to be broken when you take it out the box, does havibg 2 vs 3 pawl make any difference?
Correct. Nothing should be broken. You want all 3 pawls. 2 will work, not well and not for long. Freehubs and their pawls have a long history of being problematic from time to time. There are tips and tricks to get the pawls to behave when installing. My favorite, if spinning it ‘backwards’ while pushing it on doesn’t work, is to use a ziptie to press the pawls in, slide on freehub, remove ziptie. Good luck and get a replacement for that broken one.
