Zwift Click Keeps disconnecting
Zwift Click disconnects very often. It feels like every 3-10 minutes. Sometimes i see the blue LED light up, sometimes not.
It started months ago and is getting worse and worse. It is nearly unplayable now outside of ERG-mode.
From the start I have tried to troubleshoot and do the guides here on Zwift and other websites.
Setup:
Zwift on PC Windows 10.
Zwift HUB.
Companion app on android phone.
Zwift Click & Cog
Polar H9, HR monitor
Elite Sterzo Smart.
Connected through the APP.
-I have followed the guides on this website.
-Reinstalled both companion app, and Zwift on PC.
-Disconnected and reconnected everything. (Also tried only connecting the Zwift click).
-Updated everything.
-Deleted the “knowndevices.xml” + restart.
-Moved everything around to not get interference.
-Restarted Bluetooth.
-Restarted WIFI.
Maybe I have forgotten something on this list because I have tried a lot.
Everything but the Zwift click is working fine. I dont have real gears for my bike so it is needed for me to use Zwift.
I can see I’m not the only one with similar problems, but I’m not sure if they fixed it.
I need some help with the next step please.
Assuming that the Click shifter is OK (which hasn’t been proven) the thing I would try next is a Bluetooth dongle on a 2m extension cable and disable the existing Bluetooth adapter. What is the Bluetooth hardware you are using now? Is it built into the PC?
Two USB Bluetooth adapters I have used personally are the TP-Link UB400 and the Edimax BT-8500. There is a guide to Bluetooth adapters here:
If the PC has onboard Bluetooth, the guide recommends disabling it in the BIOS, but you don’t have to do that. You can also right-click on the adapter in Device Manager and select disable. You do need to unpair (forget) any devices that were previously paired to it in Windows Bluetooth settings before you do that.
You can also upload log files to zwiftalizer.com and it should tell you if there are Bluetooth disconnects. I assume there will be. Unfortunately it doesn’t tell you why, so the problem could still be on either side of the connection.
Hi Paul.
Thanks for replying. It is all connected through the phone. I don´t have bluetooth on my motherboard.,
I did a test the other day with a noname dongle I loaned from a friend (forgot that on the list :wink: ) I had Zwift open and could see it disconnecting ingame.
I just used Zwiftalyzer to check two resent logs. About 10 bluetooth disconnects in about 30 minutes. After that I gave up and rode the rest in ERG-mode.
Hi @Thomas_Hansen6,
Thank you for posting! I am Nelson from Zwift Support.
Thank you for your detailed description of this matter. To assist you properly, we’ve sent you an email and requested some information. Please check out your inbox, including your spam folder, so you don’t miss any updates.
In the meantime, check out this article to prevent Bluetooth disconnections.
Feel free to reply to the email we sent or to contact us at Zwift Support, and we will be there for you.
Hey. Was this issue solved? Got the same problem
Zwift click, wahoo kickr core, garmin hr monitor, aftershokz headphones
All connected via BT to samsung tab s10 fe plus. No interference except Zwift Click. Signal drops every 10 min for like 1 sec. Super fast spinning. Reconnect. Again and again…
Got the same setup with my PC and BT dongle - all was running smooth. So no clue why zwift click is not running properly now
Same problem here. Everything worked fine until about a week and a half ago. Now I’m constantly getting dropouts from the Click. I’ve already installed a new Click, but nothing helps.
My Zwift Click V2 also disconnects several times during a ride. I am moving over from a Zwift Play which worked well. No disconnects. I was considering using the Zwift Cog but won’t with this problem.
