Zwift Click connection issues
Ive had a click which was bought with the Kickr core 1 hub bundle. ive used it a handful of times and it has not worked for a full ride yet.
I am getting constant drop outs and after a while it just disappears all together. i am waiting for Zwift support to get in touch but wondered if anyone has experience of this that could help.
Running Window Zwift only PC over bluetooth. All latest updates are done. I tried pairing through the phone but my wifi doesn’t appear to be strong enough to keep a constant connection and dropped out everything.
Ive not been able to complete any event properly to date and his making my zwifting experience horrendously frustrating. Never had major issue with the platform until i bought this.
Any help would be good.
Hi @Mike_Henderson2, welcome to the forums!
I’m Fernanda, from Zwift.
I couldn’t miss the chance to help you with these drops of connection you are experiencing with the Zwift Click, let me tell you that I found the ticket you opened with our email team and I move forward and share with you the next steps to follow! Let’s continue our interaction there and drive you to a solution!
Keep an eye on your inbox.
i had the same issue using MBP Sequoia 15.0
Hi @Clement_Chan, welcome to the Forums! I’m Juan from the Zwift Support team.
Thanks for sharing your concern here. I understand how important it is to maintain a reliable connection with your Zwift Click.
To address pairing issues, I recommend checking for Bluetooth interference in your setup. For troubleshooting Bluetooth scenarios, please click on this link: Bluetooth Troubleshooting Guide.
Additionally, could you confirm the brand and model of your trainer? This will help us assess compatibility.
Please keep us posted either here or at support@zwift.com for personalized assistance.
Hi , the zwift app can pair my trainer , HRM and cadence sensor. the zwift click also can pair the zwift Companion app and do the firmware update .
Hello @Clement_Chan
Shuji at Zwift HQ here. I’m scanning your server log history and I’m seeing a Wahoo KICKR on firmware version 3.3.61. Looking at Wahoo’s firrmware release note history, that appears to be a KICKR v3 (2017), is that correct?
Wahoo has confirmed that KICKR version 6 (and future generations) can support virtual shifting. In your case, the Click does not appear in the Pairing menu because the trainer doesn’t support virtual shifting.
If you’d like to return the Zwift Click, please get in touch with our colleagues..
My Click worked perfectly with the kicker core for a few months. recently I began to get drop outs during my rides. I am connecting to apple tv via the companion app. HRM is fine, when Click drops and I go to the paring screen it often doesn’t appear. I have changed the battery and made sure all firmware is up to date. Any suggestions? Thank you in advance
It’s likely the common problem where the Click bends slightly and then the battery can lose contact with the terminals.
Any ideas on a fix? Just bend it back?
My click is doing the same thing. I did all the corrective steps I have been able to find including updating firmware and file removals from /documents/zwift and still “NO SIGNAL”. It worked maybe a dozen times on a bike that always stays on my Kickr Move and today I missed an event.
Hi @William_Pulling
Welcome to the forums. I’m Haziel and I’m part of the Zwift Support team. I’ve noticed that you already contacted us, and also reviewed your ticket and noticed that there’s already a reply. I’ve also noticed that Zwift Click is showing version 1.0.0. Please note that the latest version is 1.1.0. I recommend that you complete an update by following the steps in this article.
If the issue persists, please reply to the email and we are going to continue assisting you.
I just checked the click with Zwift Companion App and it immediately indicated that “Firmware is up to date” and was showing 1.1 already without me taking any actions. I don’t know where you were seeing 1.0, but unless you were pushing automatic updates the info you have is incorrect.
This issue is not resolved.
