Zwift bug 2000w
Hello everyone,
for no reason I have a problem transmitting watts via my elite suitoT. It displays 2000w even though I barely press the pedals. The calibration of the home trainer is stuck at the 3rd step out of 5. What should I do?
What are you using to calibrate it with, you should use the elite app & not zwift
i use zwift
Calibrate it and test ride it using the Elite app, without running Zwift. If that fails, contact Elite support.
use the elite app
okay I’ll try
Thanks :slight_smile:
Same issue on Elite app :frowning:
in that case I think I’d contact Elite support
