This is a list i’ll be working on as I go through more of the features on Zwift Android Mobile and i’ll be posting anything that I come across that seems be an issue.
_ Device Specifications: _
_ Mobile: Samsung Galaxy S8 _
_ Android Version: 8.0.0 _
_ Carrier: T-Mobile _
_ Broadband: Cox Communications _
_ Zwift Version: v 9 - 1.0.27632 Pro _
Updated Issue - 07/05/18
Unable to give “Kudos” by click the Thumbs Up icon
Had an issue when I exited out of the application then I restarted the game it went as far as the splash screen then would exit back to my home screen. The fix I had to go into the Application Settings on the phone and clear the data & cache then it was able to reload all the info and load fine. Its been fine ever since and has only occurred once so far
Updated Issue - 07/06/18
I have recently attempted to connect my Viiiva Heart Rate monitor to my phone to be able to establish a connection between my Garmin Speed & Cadence Sensors. I did test this on my iPad which was working flawlessly before I then tested it on my Android Phone it is unable to find my Viiiia Heart Rate Monitor it doesn’t find it while going into the “Speed Sensor / Tap To Pair” or “Heart Rate / Tap To Pair” the Viiiiva doesn’t even show up at all on the lists now here is what I’ve tried.
- Restart Phone
- Unpair HRM / Repair HRM
- Disabled Bluetooth On Other Devices To Prevent Interruption
It does find the Viiiiva Heart Rate Monitor inside the Viiiiva App, and it does register my Heart Rate, Speed and Cadence Sensors but when I switch over to Zwift it doesn’t pick anything up at all so I am unable to use the Android Version at this time.
I also do realize I have to close the Viiiiva App before being able to use the Heart Rate Monitor on other apps as Bluetooth has limitations on what it is able to connect to and how many at one time.
Any suggestions??
