when I do structured workout (e.g. Intervalls) witgh my Neo and I have to stop for a few seconds only, Zwift tells me that it’s temporarly paused.
When I continue to pedal all is fine except the resistance seems to be lost (e.g. instead of the targeted 300 Watts I can push as hard as I want but can’t go over 200 Wants). Also skipping the intervall (with the Tab Key) doesn’t help. I have to exit Zwift, start it again and select the same workout. Of course I can use the Tab Key to forward to the intervall section I was before but IMO this is a bug which could be fixed
I have tried that twice but it still behaves the same.
Being in a workout, stop pedalling until avatar stops. Zwift tells me that ERG mode has been paused temporarly and when I re-start pedalling ERG is not enabled anymore
Before submitting a ticket, can you please make sure your NEO is up to date?
Also, a lot of people actually don’t know how exactly the ERG mode works, in case you are unsure I’d recommend you to check THIS article explaining it all.
