Workout setting
Hi all, I’m using 7-d free trial now and is thinking to upgrade to monthly plan. I’ve started a 6-wk buildup plan for 3 days already, and want to increase the loading. Any clue to change the load setting in-between workout plans? Or should I quit the current one and have a new one?
Cheers,
Tomy
Just increase your FTP and carry on with the plan you’re on. That will make workouts harder.
Do u mean having a ftp test, then the system workout will adjust automatically?
Hi @Tomy welcome to Zwift.
Yes if you do a FTP test or ramp test your FTP will be adjusted automatically.
Thanks @Gerrie_Delport
You can also manually adjust your FTP.
Click on Menu, Click on the Pencil under your name, In the FTP box you can manually change it: https://support.zwift.com/de/user-profile-(age-weight-ftp)-Hkl5lAJWBX
