I’ve been using Zwift for about a month and want to provide good feedback and user input.
Would be great to be able to add and edit custom workouts without having the app synced up with a trainer, or better yet from a website outside of the app.
If time blocks would snap to time segments like 4:00 minutes or 5:30 or be able to enter these time and power values with the keyboard, it would be much easier to build solid refined workouts.
You can edit your workouts even when not connected to a trainer. Just select Just Watch and then press E, it should pull up your workout selection screen.
I would love to be able to do more from the website and hopefully it is coming soon.
Here is a manual that could help in your experience in Zwift: http://www.titaniumgeek.com/cycling/zwift-user-manual-unofficial-running-updates
I’m not in front of a PC with Zwift on, but I’m sure you can already do those things…
If you launch Zwift and then go into spectator mode (bottom left where it says something like “just watch”).
Once in there just press “E” on the keyboards and you’re into the Workout screen.
As for entering values with the keyboard, if you click on the values in the editor window you can type the values directly in.
