Zwift just won’t start on my iMac running Windows 10. I’ve already tried updating the graphics card driver (directly from AMD and from BootCampDrivers.com) - without succes. Any suggestions? Thanks in advance.
I created a new partition for Windows. Downloaded a fresh copy of version 10. Installed it (Bootcamp). Ran a whole bunch of updates. Installed the .net framework. Found new updates an installed them. Finally I downloaded Zwift and made a default installation. Same result: Zwift can’t open its own files. What the heck!
I already tried to run Zwift as an admin and changed the rights of the assets. Zwift still doesn’t start.
One thing I forgot to mention: The copy of Windows is a 64 bit version. On a website I read, Zwift stopped the support of its 32 bit version. However the program is installed in the x86 program files folder.
This is actually something we hear about once in a while. Running Zwift on a Mac through a Bootcamped Windows OS isn’t a supported set up. Your best options are to run it as the MacOS version of Zwift, or acquire an actual Windows machine to run it on if you need to run the Windows version for whatever reason.
Please tell me that’s a joke. Bootcamp isn’t some special OS, hacked setup or virtual/emulation set-up, it’s just a computer running Windows 10 64-bit with drivers for the Mac hardware and is compatible with pretty much everything. I used this for software development so I should know. The log files indicate that it cannot find the appropriate wad files etc when they are clearly there. Zwift goes through the Windows API so it should be completely transparent.
So I’ve come back to Zwift, started my monthly payments and on a 2019 MBP with Bootcamp I get the same message. All graphics drivers are up-to-date (etc) however the logs indicate it simply cannot find the files. This seems to me like either the logs are not indicating the correct problem or there’s some bizarre bug somewhere. I assume this is a 32-bit app because it installs in the x86 folder on 64-bit Windows 10.
Seems you have a bug in your wad file loader. The logs spew out stuff like:
[14:56:31] Log Time: 14:56:31 2020-01-04
[14:56:31] Game Version: 1.0.44368
[14:56:31] Config: Shipping
[14:56:31] Launcher Version : 1.0.50
[14:56:31] Loading WAD file ‘assets/global.wad’ with file.
[14:56:31] ERROR: Could not load wad file: assets/global.wad
[14:56:31] Loading WAD file ‘assets/environment/ground/textures.wad’ with file.
[14:56:31] ERROR: Could not load wad file: assets/environment/ground/textures.wad
[14:56:31] Loading WAD file ‘assets/UI/WhiteOrangeTheme/WhiteOrangeTheme.wad’ with file.
[14:56:31] ERROR: Could not load wad file: assets/UI/WhiteOrangeTheme/WhiteOrangeTheme.wad
[14:56:31] Loading WAD file ‘assets/UI/minimap/minimap.wad’ with file.
[14:56:31] ERROR: Could not load wad file: assets/UI/minimap/minimap.wad
[14:56:31] Loading WAD file ‘assets/UI/WhiteOrangeTheme/Scotty/Scotty.wad’ with file.
[14:56:31] ERROR: Could not load wad file: assets/UI/WhiteOrangeTheme/Scotty/Scotty.wad
[14:56:31] Successful audio init!
[14:56:31] Loaded audio banks
[14:56:31] Initializing graphics window of size 0 x 0
[14:56:31] Attached Monitors:
To be clear, I was responding to the “support” post above. There’s simply no good reason why it shouldn’t work on “bootcamp” as it’s not any kind of emulation or virtual OS set-up just another PC with the appropriate mac drivers.
did you already find a solution to this problem? I’m also having this error on my bootcamped MBP '17. Keeps on saying can’t find the WAD files. Is there any script that makes Zwift look in a different folder, since the files are actually on my computer.
I have this exact same problem on a 2017 retina macbook pro. I’ve attached a debugger to the ZwiftApp.exe and the messagebox is coming from a call to AK::StreamMgr::SetFileLocationResolver, specifically its being raised by the AK::WriteBytesMem::SetCount (+ 0x1ce850).
So it looks like the problem is coming from AudioKinetic …
Any fixes would be massively appreciated as I hate OS X
Hey guys! I have exactly the same problem on my 2017 MBP. Has anyone found a solution? This is unfortunately the only way I can run Zwift on my Mac, as I need windows-specific software to connect my trainer to the computer
Thank you for posting the solution!!
I just started with Zwift and I ran into the same issue with a new HP Probook laptop with an M.2 Solid State Drive.
I’m an IT specialist and judging by the errors and how it works off a secondary drive I think the issue is related to how the game tries to interact with the harddrive and Windows tries to protect it from that interaction. Its weird but putting it on an SDCard solved my issues.
