Where is the Arch in Workouts when cycling in Video
Hello to all,
I recognized that the arch, which is indicating a new powerzone, in workouts is not displayed. The sound comes up, but not the arch or halfcircle, however you name it.
It is only when cycling Workouts in the new Viedomode. When cycling in watopia all is fine.
I am using an iPad Pro M4, latest OS and latest Version of Zwift, Zwift hub and Zwift Click and play.
Any Suggestion? Do you have the same experiance?
Many thanks
Andy
That’s been noted several times in the forums that the workout interval arch is missing. It’s on the Mini-Map, but not on the road.
I have not seen anything from Zwift on when or if the interval arches will be added to Video.
From what I’ve gathered, adding non-static virtual items to the videos isn’t an easy ask. Everything they have added (banners, chevrons, barriers, etc.) is always in the same location. Even the ‘Ride On’ thumb works correctly, because it’s tied to the rider position. But the workout arches could be anywhere, which makes them problematic (apparently).
I’m not sure I fully understand the technology, though, as I would think adding them would be similar to having them in the climb portals, where they work ‘as expected’. Perhaps the issue is that if the same process were used in the videos, we might see an arch that is really supposed to be behind something (car, hill, whatever). But, personally, if that’s the only issue I’d rather have the arches. They are only there when doing a workout, and only in the last 2 minutes of the interval. I’d love to see them added.
On the last video ride I did a few days ago, I also didn’t see any confetti when I gave someone a Ride-On.
