I tried to join the ITT race scheduled for 9pm EST today (Nov. 29, 2022). When I came into the start pens, it said that I was going to be released in 1:29, and it just stayed at 1:29 for about a minute, at which point it counted down to 1:28. This was my first time trying an ITT. About a minute later the timer had counted down to 1:27. (I actually thought, maybe it means an hour and 27 minutes, so I asked in the chat, and people thought I was joking. Also it wasn’t counting down at exactly a minute, more like 45 seconds for each “second” from 1:29.)
As this was happening, my avatar kept drifting backwards relative to two other avatars near it and then suddenly jumping forward to be next to them again, over and over again.
I then tried exiting the race, but was unable to rejoin (have you turned it off and on again?) because at this point it was about 9:02 pm, so the event was no longer showing up in the UI. (Perhaps with TT races, they could linger a bit if you are signed up for them on the front UI so you can get back in if you were in the pens?)
I’m running Zwift on a Mac, and the client is up to date. I’m happy to get more system information and/or logs if any are relevant.
Had this bug today as well. Also noted that onscreen message prior to joining the event indicated a start time in over an hour despite the companion app indicating start time in just a few minutes; should have took that as a hint I guess.
Signed up for event about 10 minutes ahead of time which was even a few minutes before the first rider would have gone off.
Trying to post a waiting screen grab, note the 1:21 is apparently hours:minutes
Like I said, based on the chat, it happened to multiple people the same night it did me (I got a scarcely-deserved gold trophy riding up a category from what CE and ZwiftPower give as minimum)
I’ll see if I can get in touch with any of those folks and ask them
I’ve had this happen twice now when going to the pen for the Zwift TT club races.
Tonight I decided to let it be rather than to quit and rejoin just to see what would happen.
It did not put me in the pen so missed the race.
Windows 10 and used the Companion app on IOS to sign up.
That’s what I did James.
Was warming up in Zwift (actually testing the legs to see if they were up for it) and signed up for the iTT with Companion app.
Another known workaround, if you enter the event and get the wrong start time and are placed at the back of the paddock, just exit the event and go back to the home screen.
When you re-enter the event, you will be put in the correct position of the paddock with the correct start time.
