Wattbike Proton gear display
Please implement the gear display on the Wattbike Proton as you have on the Wattbike Atom. It will make using Zwift a lot better.
Matt
Gear display no longer working for me after last zwift update on wattbike atom. Wattbike says it’s a zwift issue. Very annoying, so I am just chiming in in solidarity.
Zwift customer service emailed and said that many problems with gear display are present and they have no timeline for a fix. Charming.
Same, I have no gear display with the atom or the proton.
Gf has always had gear display with Atom V2 dunno why you don’t Jennifer. Maybe you need to update the firmware by performing a “quick ride” on the Wattbike hub app.
I did have a gear display with the Atom but it disappeared, even after updating. It’s a strange one! Never had the gear display with the Proton, though, which is frustrating.
The gears are still showing for my Atom v2 :person_shrugging:
I have just set up my Wattbike Proton on Zwift and I cannot see the gear display in the HUD. I am running Zwift through Apple TV and it’s updated to the current version and Zwift is also updated. Does anyone else have this problem
There is no gear display in Zwift for the Proton
Thought that might be the case … Thanks Paul
Hopefully this gets resolved soon - it’s annoying. Should be an easy fix
Hi folks,
Will Wattbike (Proton) gears ever be added to the Zwift UI?
I’ve tried searching this in the forum but can see some people who have it for the Atom, and others who don’t have it at all (like me).
Very confused as to why some do and don’t. Is it me? Am I missing a setting?
You’ll have it on the Atom unless you’re running Zwift on Android, iirc. Works just fine on PC.
The Proton is a wait and see. Give Wattbike a shout and see if they have a roadmap.
I really hope this doesn’t get forgotten, it would be a real luxury
Just wandered if anybody has had any update from Zwift on this yet? Is there anything in the feature roadmap to implement Gear Display for the Proton (one for any Zwift officials).
I have a Wattbike proton and been using on Zwift for nearly 6 months now. So starting to get more into it and doing races etc. But not having the Gear display is really annoying and not a great experience. I would have got a Zwift Ride ideally, but needed something that the Wife and older Son could also use. So Proton is great for that and generally works good on Zwift. But please just implement being able to show what Gear I am in​:+1::hand_with_index_finger_and_thumb_crossed:
Any update on this one please? Is gear display for proton on the roadmap?
No Gear display for Wattbike Proton-Is there any timescale for when/if this bug will be fixed? Thanks
Very reasonable request, but not a bug since the feature was never released for the Proton. Same for several other smart bikes as well. AFAIK the Atom is the only Wattbike that got a gear display in Zwift.
Even a response from the Zwift team would be a step forward :disappointed_face:
Zwift are blaming WattBike for the problem and their not keeping up with firmware changes which is rubbish, it worked briefly a year ago. Not so worried here, got the WattBike Atom X so it has a huge Android colour display on it anyway with it displayed bottom left and I can change gears both on the touchscreen or the right bar buttons. These days I have started to hit “H” and totally remove all the HUD anyway for pacer rides at a Z2 training pace, you simply don’t need the text and run the script that changes the camera angles every 15 seconds and just enjoy the scenery.
