Just wandering if I’m the only one having issue lately about wattage and cadence dropping to 0 for a few seconds and returning back to normal. This will happen in both Workout and Freeride mode. I’m using a Tacx Vortex Smart using the latest firmware from Tacx Utility App.
I’ve been using the same setup for about 5 months now and only started to see this issue for the past month or so.
I had the same problem using a Vortex Smart. Bizarrely after checking the forums the problem was solved by getting a USB extension cable allowing you to place the Ant dongle closer to the trainer, half way between the two works for me. Issue was poor signal. If you use a big screen with a lap top trying angling the laptop so the dongle can see the trainer to test. Simple but it resolved the issue straight away.
I went and purchased a longer USB extension cable over the weekend. So far did only 2 hours with the dongle closer to the trainer but didn’t get any connectivity drops. Thanks a lot for the quick feedback.
