Im having the issue that a kicker can get “ghost-watt” increases if two Wahoo Kickrs are in one room
The setup is:
Wahoo Kicker 1 - Apple TV - Connected with Zwift Compagnion
Wahoo Kicker 2 - Macbook - Connected with Bluetooth
Both pair the sensor prior the ride, all a sudden on of the Kicker has issues with the watts and the ride continues even when not peddling.
First thought was that there could a some interference as the bikes are standing less then 2meters apart but even moving one of the bike to the room next door did not resolve the issue.
Anyone having similar issues ? How could this be fixed?
Thanking you in advance for your help.
Unfortunately this was never really solved with absolute certainty. In the meantime we have sold on of the equipments.
What has worked was to delete all sensors from all your mobile devices in the entire home - sometimes the devices sync the bluetooth infos in between. What then happens is that they might connect to another device and create the issue.
Clean them all and redo the setup only on the ones that are relevant. Hope this will sole your issue
