Yeah so bluetooth connection to Kickr Core is absolutley rock solid but to my Tickr (latest version) the connection constantly drops…constant i mean, every 30 seconds it seems.
My HR disappears from the HUD and i constantly get the “connection lost” banner at the top of the screen.
I’ve tried numerous new batteries - still happens
EDIT - Pairing in the beginning no issues whatsoever.
Super fast
I seem to recall other threads in the Forum where people have numerous issues with the Tickr, across multiple setups. My guess would be this is the issue.
I’ve had issues with tickrs, but never this problem. (The typical “fail” I’ve experienced is that it gets “stuck” at a particular heart rate.) I recently had something similar happen with my polar (which I now mostly use), but I think it was either a battery issue or some sort of interference issue (kids home from college using their own Bluetooth devices). Could you test by using the Tickr to connect to another device — like a watch?
I have owned no less than a twenty HR straps, from chest to armband optical.
Wahoo Tickr: no end of problems, ended up returning it. It would drop connection to something as simple as a Concept2 RowErg. There’s some speculation that Wahoo got a bad batch of BLE chips but their issues with connectivity (search the forum) span multiple years and devices, including their trainers, so I’d be more inclined it’s a long-standing design flaw.
Polar H10 which has been rock solid for years, never failing to connect or dropping a connection to anything.
Random, cheaper, lesser-known brands like the Coospo 808s (a rebranded Biostrap): great!
Garmin great, until the moment they decide to prematurely fail, usually after a battery swap. Garmin’s old-style battery door with four, tiny screws has a propensity to let moisture in, no matter how well you resealed it. They’ve all died on me in about a year. (old school, ANT+ only HRM1G is indestructible)
Garmin HRM-Pro+: bought one last season as it uses a tool-free battery door which I’m hopeful solves the seal issue. (jury’s still out on that)
The H10 is my go-to for Zwift and I’ll give the HRM-Pro+ more testing during outdoor bike season.
TL;DR: buy a Polar H10 and don’t look back. On a budget, try a Coospo 808s.
Cheers for the replies.
So does seem im not alone.
For what its worth, i only just switched from PC and then for a bit i used a dell laptop…both of those were fine with the Tickr.
Since i moved to ATV, thats when the problems started.
My gut feeling its not the Tickr on its own but a combination of an issue when used with ATV
I had nothing but issues with Tickr. About 5. Finally pitched it for a MOOFIT. On Amazon half price. Works much better than Wahoo rubbish. I had them bad out of the box. Done with them . Im mid 70s cardiac issues. Ride daily and need HR
THIS!!! I am perplexed as to why they designed this with the ‘four screws’, instead of the ‘twist top’ that the old speed/cadence sensor used to have. So much simpler! And, while I’m ranting, why doesn’t the Garmin strap have a bigger ‘hook’ on the clasp? Mine comes undone all the time because it just slides right out of the loop.
I’ve owned several of those - they’re the ONLY Garmin HRM (the HRM-1G, if you’re trying to find one) that are practically indestructible. ANT+ only, no BLE, but unkillable. I’ve found them for $2.00CAD ($1.59 with a coupon LOL) at local thrift stores and love to keep one as a backup.
