HELLO !!!
OLA ![]
I need some HELP
i started make zwift at 10 months ago and i have some experience about smart trainning.
i have in beggining the Tacx Flow after i Change for Elite Directo and now i have the Wahoo Kickr (V5) at 1 week ago.
i Have a team in Zwift World Name FCancerTeam ( if you need join us all category ) but i see my date day by day more low and low …
Iknow my performance( because i m teacher of exercice )and in the moment i m A+
but with whaoo kickr in all races my AVG is 4kw or 3,7kw or 4,2kw, normal in other races with Elite i finish AVG 4,8kw or 5kw.
ok after this i m desapointed , normal, because i put all in pedals and up and down all times the Watts.
i have make the test with :
1 - figure one old race( Elite directo and Rotor in Power )
2 - new race with ( wahoo kickr and Rotor in Power )
and the result is too much difrence, anyone can help me please ?
After this email i send to wahoo support
Feb 13, 2021, 11:21 PM EST
Hello,
Thanks for contacting Wahoo Fitness. Try these steps to reset your KICKR’s Bluetooth connection:
- Un-pair your KICKR from any and all apps/devices you’ve ever connected to.
- Forget the KICKR if it is listed under your Bluetooth settings
- Toggle Bluetooth off. Please note, this needs to be done from within the Bluetooth menu of the Settings app. Doing this in the Control Center does not fully turn off BT.
- Turn off your phone
- Reset your KICKR (unplug for 30 seconds, plug back in)
- Turn on your phone
- Turn on Bluetooth
- Open the Wahoo Fitness app
- Go to the Sensors page
- Choose the option to add your KICKR
- Make sure the KICKR is awake
- Choose the KICKR and save it
- Now perform a regular spindown in the Wahoo Fitness app.
If you’re unable to complete that spindown, please go through this interactive support article and let me know the results
A reminder regarding comparing the KICKR power accuracy versus a 3rd party power meter, is a combination of the factors will impact power reported at the crank versus the KICKR (for example: the chain can cause an additional 5% difference in reported power at the rear hub versus power reported at crank). These factors include the following:
- set up of the 3rd party power meter
- condition of the bearings in the pedals
- installation of the 3rd party power meter
- calibration of the 3rd party power meter
- firmware of the 3rd party power meter
- drive-train condition
- bottom bracket condition
- gearing used when testing
- temp of drive train when testing
- condition and lube used on chain when testing
- condition of derailleur pulley bearings
Ultimately, due the large number of factors that can impact the power reported at the crank versus the rear wheel, you can see large power differences (with both the KICKR and power meter properly reporting power).
All these factors will impact power reported by the KICKR versus power reported at the crank (by the 3rd party power meter). Ultimately, due the large number of factors that can impact the power reported at the crank versus the rear wheel, you can see large power differences (with both PM and KICKR reporting accuracy within specs). Please also ensure the user is taking into account that each power meter (and the KICKR) will have a accuracy rating of +/- 2 to +/- 3%. In other words the KICKR could be considered within spec at -2% accuracy and the 3rd Party PM is within spec at +3%. This example would yield a difference of 5% (without including the external factors outlined above) . When the factors above are included, can yield a difference of over 10% between a pedal based 3rd party PM and the KICKR. Please reach back out if you have any other questions.
Thanks,
Karli
and AFter this i try contact support and nothing and i have make others test with others smart trainners
i have make all you have make for he do and same situation.
today i have recording with a other ELITE and other Kick Core and this have same situation…
and firmware update? no need new and pass etc ? i have try with old version 4.1.2 and and new version 4.1.2 and same more of 10% difference
ELite Sunto VS Rotor
ELITE Directo VS ROTOR
Wahoo kickr VS Rotor
and … what is the problem…
