Using Wahoo Bolt while Zwifting
Hi all,
I’ve just bought a wahoo bolt bike computer that I’ve started using to get more data feedback when zwifting. I’ve noticed however that I’m now getting quite a few drop outs on Zwift. Is it generally that you can’t use both at the same time or do I need to do something to get it to work?
I’m using a kickr 18 if that is of any use.
G
Connect the bolt via ANT+ and Zwift via BTLE and you should have no problems.
Bluetooth signals might be interfering with the signals from the KICKR to the device running the main Zwift app.
If you’re running Zwift on a PC or Mac, you can use ANT+ for both the computer and the Bolt, simultaneously.
