Treadmill not recognized [August 2021] [1.16.0] [SOLVED]
Got it working. Deleted old app from
iPad and downloaded new one. Now works
For next time, there’s no need to delete the ā€˜old’ one when there’s an iOS or iPadOS app update.
Assuming you don’t have automatic updates active, just go into the App Store app and tap your profile icon at the top of the screen to show the list of available app updates for your device. Then just tap update for the app(s) in question, when available.
If the announced Zwift update isn’t available there (apparently it takes differing amounts of time to be pushed to servers depending on geographic location), you might make it appear by pulling down and releasing the list, in order to actively fetch what hadn’t been pushed yet.
Thank you :grin:. I’m a happy runner once again.
Still showing as version 1.16.0 for Android after reinstalling Zwift. When can I expect an update ? I’m connecting my rower through Bluetooth using the RowedBiker App on a second Android phone.Rower shows up as a Ride device but not as Run. Will the new update fix this issue as well? Thx
NPE RUNN can be executed normally on APPLE TV, thanks
I’m happy to report that the problem is fixed in the update [version 1.16.1] released today. My Runn sensor shows up properly when Run is selected and I completed a run without any issues.
Update app and m my phone. iOS and tickr for HRM and cadence still not recognised at all in running neither is viiiiva HRM. I have an event in 2 days and a Zwift run pod arriving in 6 days :/(
Technogym MyRun is now connecting with Ipad. Thanks for keeping us updated
Runn TM Sensor to Apple TV for Speed and Cadence, Garmin 245 Watch for HR.
Back up and running properly - THANK YOU!
Hi Shuji,
Thank you for being here to listen to our, the Zwift running community, problems with the last 1.16.0 update. It really made a difference. 1.16.1 seems to be working fine now, as expected (Apple TV - MYRUN). Good to know that you and your colleagues actively monitor these forums.
A lot of frustrations out there.
Kind regards
Nick
System
Zwift App 1.16.1 (79343) installed.
iPad Software Version 14.7.1
iPad (6th Generation)
Treadmill
Technogym MyRun
App version 2.8.1.3
Connects to Technogym app
Visible in Bluetooth settings
Nothing comes up when attempting to pair
Have ensured that MyRun is not connected to Technogym App or IPad.
Deleted and reinstalled all apps and powered on and off all devices
Fixed with 1.16.1 update on Apple TV.
Thanks to Shuji for reassuring us this was being worked upon.
The sole F80 has been working great for me until this update. As soon as they fix the issue u won’t have any problem!
No luck for the Sole F80 on Android
Thanks for keeping us updated though!
system: iPad (8th generation), latest IOS version, Zwift App 1.16.1 updated;
Treadmill: Assault Runner
Cannot pair after update.
Is it unpaired from Technogym app when your trying to connect in Zwift? If not, you have to close the Technogym app so that the bluetooth connection is free up for Zwift to connect. It can’t be connected to both at the same time
Yes. No luck when ensuring MyRun is not paired to anything else.
That’s so odd! My MyRun works fine after todays update
Working fine after update 16.1 on my ATV. Many thanks for for the quick patch.
Updated to V1.16.1 but still can’t get pair to Air Assault Runner via Bluetooth.
