Trainerroad workouts on Zwift + Garmin
I’ve signed up for Trainerroad and I’m happily following a plan doing the workouts on Zwift. Thing is, I also use Garmin Connect for running and I’d like to get a unified view of my running+cycling performance. Garmin is so annoying that uploading .fit files from Zwift won’t cut it - they need to be recorded with a Garmin device.
So - having a Forerunner 265, how can I set the whole ecosystem up? I also want to make sure that training progress is also reported back to Trainerroad.
Are you talking about running outdoors, and getting those runs to Zwift, GarminConnect, and TrainerRoad? Or do you mean using a treadmill to run on Zwift and getting the Zwift runs to Garmin and TrainerRoad?
I’m talking about cycling, sorry I wasn’t clear.
But yes I’d like my indoor workouts to properly sync with Trainerroad. As far as I know I need to start them either on Zwift or Trainerroad itself, but if I don’t start them on the Garmin then Connect will ignore them (i,e, will not give me training intensity, calculate VO2max, etc).
I don’t use TrainerRoad, but all the rides I do in Zwift are correctly synced to Garmin Connect.
My TrainerRoad workouts from Zwift are always synced to GarminConnect. And I’m pretty sure that GC will use them to estimate VO2 Max, but the calculation of Intensity Minutes is sporadic, at best.
What do you get when you look at the “Training Effect” data? I also sync Zwift with Garmin Connect I don’t have any Training Effect data. Also, no other performance parameter estimation.
I also have Zwift sync with GC but have no VO2 Max data, nor Training Effect. Is this different in your case?
I know, and I have the same. But, for instance, that workout won’t contribute to the “Intensity Minutes” in Connect. Hence my question
Looking into this further, I might well be incorrect. I’m going to double-record my activities for a while using both Zwift and my Forerunner (this isn’t dual-recording, because I’m using the same power source, and HRM, for both activities) and see what impact it has on my Garmin VO2 Max calculations. I’ll either delete the Zwift activity in GarminConnect (which is what I did yesterday), or stop the transfer of Zwift activities to GarminConnect altogether. This will result in my Garmin indoor cycling activities not having the ‘correct’ distance or elevation, but I’m not sure how critical that actually is. (And that data will be available in Strava.)
I’ll circle back after a few rides and let you know if I’m seeing any changes.
Looking at some other threads, @Andrew_Nuse might have some insights on this.
My Garmin watch is paired to my trainer and I record all Zwift activities as indoor cycling sessions with the watch. After the Zwift activity, I edit the distance and elevation fields of the Garmin indoor cycling activity via Garmin Connect. This method preserves all Garmin cycling stats and performance metrics, and your indoor cycling activities contribute to Garmin badge challenges. This is the best method if Garmin is your primary metrics platform, or your “source of truth”.
Two notes:
  • Zwift and Garmin accounts are not linked so no worries about duplicate activities.
  • Pair your trainer to your watch as a power source, not as a smart trainer.
    • This ensures that your watch doesn’t take over as the resistance source so Zwift can control the trainer resistance (ERG, sim, and virtual shifting).
Thanks, this is REALLY helpful. What about the HRM? Do you pair it to Zwift or to the watch and use the watch to broadcast it so Zwift can see it?
I use a Garmin HMR paired to my watch and to Zwift. This captures respiration rate data for Garmin, and more reliable heart rate data recording for Zwift and TrainerRoad.
Here’s the rest of my workflow for reference:
TrainerRoad :right_arrow: Zwift (indoor workouts from TR to Zwift)
TrainerRoad :right_arrow: Garmin (outdoor workouts from TR to Garmin Edge)
Zwift :right_arrow: Strava (completed Zwift activities to Strava)
Strava :right_arrow: TrainerRoad (completed Zwift activities to TR)
Strava :right_arrow: Intervals.icu (completed Zwift activities to ICU)
Garmin is not synced to Strava. I manually import Garmin outdoor rides and Garmin strength training to Strava, then Strava passed them to TrainerRoad and intervals.icu.
Does this mean that your outdoor Garmin activities are not synced to Zwift?
Correct, no Garmin :right_arrow: Zwift.
I don’t find value in bringing my outdoor rides into Zwift. Others may :call_me_hand:
Why would you do that?
I also do not import outdoor ride data to Zwift. I don’t see the value in doing that. Default answer to “can we have more data” is no, so there needs to be a reason.
So my old Fenix5S+ did not produce speed or distance numbers so this wasn’t as big of a deal.
My newer Fenix7Ps does produce speed/distances.
Good news there is my distance numbers are far more accurate than the mileage Zwift produces.
I have to delete my garmin activities from Companion daily since I [rarely] but do ride outside. For some like Steve though it’s one less thing to do. However, I’m also not sending Zwift to Garmin either. The load, trend, etc. data though seems to update near instantly so it’s not a total faff if I fall behind a day or two.
As some of us have stated; this would be a lot easier if Companion ignored all “indoor ride” coming from Garmin, but our cries haven’t been heard.
If you do have an additional power meter though and the reason why I do things the way I do, is I’m using the ANT+ PowerMeter connectIQ app to dual record all indoor rides.
Basically it just allows you to have bluetooth and ANT+ power recordings simultaneously.
I do it this way on my watch with Kickrbike and Assiomas, and with my Tacx and whatever bike I have on it (which is a spider or crank PM).
So in my case, Zwift is all Bluetooth, secondary power is Bluetooth to Garmin device, primary power is ANT+ to Garmin.
What I have noticed however is that Zwift’s Vo2 estimations have improved and for a while has been pretty spot on with what Garmin Connect shows me. But that doesn’t answer Stefano’s statement.
The reality is, even with all of these connections, products like Garmin Connect are really only designed to work when you’re staying in the family of products, and that’s… so you use the product, not feed a competitor.
I will however state, the only real place I use to view all of my data weekly is Intervals. But I do look at my garmin stats maybe once or twice a month, so I am reliant on the data existing, but I don’t keep up with it daily/weekly like Intervals.
Side note, appears that ConnectIQ app hasn’t been updated, someone made a newer one with some added functionality like cadence and balance recordings as well:
Side note; these are relatively useless in Garmin Connect’s website. But you can make use of the data in Intervals and show both on the power line graph and compare:
Wouldn’t importing outside rides be important to anyone using the Zwift Coach? Or if you’re away from home (with a bike) and don’t want to burn a Streak Saver?
Sure there are plenty of reasons, just not any that matter to me. I’ve been indoors since the coach feature launched, and it doesn’t support the type of training I do, but maybe by spring it will get there. I’m willing to burn streak savers and give up the little XP offered by the outdoor rides. So for me, no reason to import the data. I have a bias against data sharing which others might not care about, so it would take more to get me there.
