Hi there,
I bought a new Van Rysel D500 trainer. I have no experience with trainers, and I’m not a cyclist, but I wanted to increase my Z2 and general cardio load alongside my running. I started using my own bike about a month ago, and recently decided to get the Zwift Ride because I prefer having a dedicated, clean-looking setup in the middle of my living room.
Now, I’m a bit confused about how to integrate my workouts and data into Garmin. I connected Garmin Connect to Zwift, and the rides upload correctly as Virtual Rides. I can see all the data, but I’m not sure if Garmin is using it to calculate my FTP, or if it’s using the FTP that Zwift gives me every now and then.
For example:
Once, I manually updated my FTP on Garmin Connect.
Later, Zwift gave me a new FTP.
Garmin didn’t update automatically.
Then at some point, I noticed a change — but I’m not sure when or how it happened.
So right now, I don’t understand how Garmin handles FTP from Zwift.
Is it:
Automatic but delayed?
Automatic but using its own calculation instead of Zwift’s?
Not automatic at all unless I update it manually?
I’m using a Forerunner 970 and I have a ton of running metrics. But for cycling, I only see the FTP tab in Garmin Connect, and on the watch I only see VO2max and FTP. Am I missing something? Should there be more data or progress charts?
Also, is there a better way to import Zwift rides into Garmin?
Should I start an indoor cycling workout on my watch at the same time? And if so, how would the watch get the trainer data?
I hope this makes sense. I’m just trying to understand how to use Zwift and Garmin together, how to log my training properly, and how to get more cycling metrics — because right now I barely see anything. A lot of cyclists seem to use Garmin, so I’m confused why I don’t have much data at all.
