The power data on Zwift is different from the power data shown on ZwiftPower
Uploading: KakaoTalk_20250715_112142192.jpg…
Uploading: 캡처.JPG…
There is a discrepancy between the power data displayed on Zwift and ZwiftPower. For instance, my 15-second power appears as 6.9 on Zwift but only 4.7 on ZwiftPower. This issue has been ongoing for quite some time. Is there a way to correct or synchronize the data so it displays properly?
zwiftpower can take a while to show the data correctly is it showing a blue or green lightning bolt on your ride?
edit : assuming I got the correct profile, its green, means you have restricted certain data that is shown on zwiftpower publicly, generally it tends to be when you make your ride private rather than public
Just to add a little more to this… it looks like your rides have always been saved as private, which means the numbers you see in ZwiftPower use the “live” data and only have 30 second precision. If you save them as public then it will transfer a fit file for the activity to ZwiftPower, which should make it match what you see in Zwift more closely. It still takes some time but usually within a few hours it should get the data. Changing the privacy setting for a past activity will only result in pulling the data into ZwiftPower if the activity happened in the last day or so.
