Vortex Firmware 3.1.14
Suunto Ant+ Ministick
if i connect my garmin heart rate strap my vortex get any resistance changes. If i disconnect the strap everything ist OK?
Does somebody have an idea?
of course Vortex Firmware is 3.1.13 ![]()
Have the same problem. But i have a andriod phone and Tacx utility (latest version) tells me I have the latest version, 3.1.9…
Somebody already said about this problem. The thing is that you mus disconnect your bluetooth tranmission with the phone. Had the same issue. There is a problem with bluetooth and ant+ at the same time. So I suppose the best option is to have the ant+ heart rate transmitter and not using bluetooth.
Yes I know. The trainer isn’t connected to the phone with Bluetooth when I’m on zwift . Even tried with the phone turned off. The problem is i can’t upgrade to 3.1.13 since I have and android and tacx haven’t realised new upgrades to tacx utility for android but they have for ios. At least I think it’s an upgrade problem
Oh, hearthrate monitor and resistance on trainer worked fine before latest upgrade of zwift
have connected my vortex and my strap via ANT+, no BT at all!
Same
found a workaround today, maybe there will be an easier way to fix. Have tested thos one time, hope this will work in future again - and think btw this procedure have to be done everytime you like to ride ![]()
start Zwift
disconnect/unpair the Vortex in Zwift (i also unoair the cadence sensor)
unplug the Vortex from power
plug in the power cable of the Vortex again
search the Vortex in Zwift an pair again / cadence ist selected automatically
search the heart rate strp
and voila: all ist working
Crazy but true - also crazy we have to this again and agein whnen start a ride ![]()
Same problem here. Garmin ANT stick and Vortex TDF with latest firmware. It worked once so I know it is functional. Thanks for the ideas - both making sure a spare iPhone I have sitting by for the update (I use Android and was lucky to have a kid with an old iPhone so I could do the required upgrade) and checking calibration is disconnected, and the sequence of startup. I was playing with the same. I was also wondering whether cadence should come from trainer or Powertap as I also have power.
Everything is made more complicated and frustrating by having to exit Zwift and key in username every time. A couple lines of code to remember last username.
Thanks again.
I have had the same problem, I’m running tracx I-vortex trainer with tracx ant stick on my laptop, it was working fine until some time last week and now I have no resistance. I have tried un-installing and re-installing zwift, un-pairing all devices and re-add them, moving my ant stick around to see is this works but sadly everything I have tried hasn’t worked???
Regards
Adam
