Sync to Garmin Connect failed - Manual upload of Zwift's fit file to Garmin Connect fails as well
Hello
Today, the automatic upload of my Training from Zwift to Garmin failed. Zwift successfully synced my training to Strava and intervals.icu but not on Garmin Connect. Yes, the Sync to Garmin is still active in my Zwift settings.
I downloaded the .fit file from Zwift and tried to manually upload it to Garmin Connect. That also failed; Garmin Connect could not handle the file and returned an error.
As a customer who has recently experienced a substantial price increase for the subscription, I am deeply disappointed that the product’s performance has deteriorated. I urge you to investigate and resolve this issue promptly.
That sounds as though it could be the Garmin side of things, if its uploaded ok to the other sites
are you able to download the fit file from strava and try uploading that?
https://www.fitfiletools.com/#/top
if that doesn’t work this site might help - try the corrupt time fixer.
Hey @RidingSchnitzel it’s so good to see you for the first time in the Forums! I’m Norman from Zwift.
We’re very committed to keeping Zwift in the best state possible. It’s interesting that the ride was uploaded to Strava without issues, could be that Garmin Connect was down for a few seconds, or maybe a network interference resulted in a slightly corrupted file. Same as our fellow Zwifters, I recommend that you try and manually upload the activity.
Another tip besides what everyone else has mentioned, is that you can download your Fit. files saved locally in your Desktop by going to Documents > Zwift > Activities. Try and give it a shot!
Downloading the .fit file from Strava and uploading it manually to Garmin Connect produced the same error.
The download of the GPX file from Strava and upload to Garmin Connect worked. However, the Power data were missing then.
Regrettably, I had to resort to using a 'repair fit file’Tool, which consumed a significant amount of my time, approximately 30 minutes. Considering the premium subscription fee of $20 a month that Zwift charges, I expect a more seamless experience, such as automatic retries for failed uploads to Garmin. This would save me from the hassle of having to manually transfer my training data to Garmin Connect.
This shouldn’t happen everytime.
When your activity saves does everything happen as expected? Do you exit to the home screen and then close zwift?
My suggestions were just workarounds for when uploads don’t work as expected but shouldn’t be the norm.
Although it was a bit laborious I’m glad it got sorted on this occasion
Thank you for this, after I uploaded my fit file there and just changed the time on my workout then it could be uploaded to the Garmin page.
