Support Tickr X & Run Cadence feature
Please add direct support for the Tickr X & Run’s running features: Cadence,
ground contact time, vertical oscillation, etc.
There’s currently a work around to enable the cadence feature … You have to get the Tickr X/Run to switch to run mode by starting a run with the Wahoo Fitness app, then swipe up/close the app. Now the Tickr X/Run can be picked up as a running sensor within Zwift.
It would be nice if this was directly supported.
Great idea :bulb:
