I have a race which sorts the results based on the KOM times. When the results are generated it looks like this (correct results, sorted by KOM time)
However, after a period of time, the results change and there are some weird results at the top as you can see here. This happens even after the results are finalized.
Re-generating the results manually fixes it each time.
Could you add this to the list of things to look at @xflintx @James_Zwift ?
Note also that rankings upgrades are not based on finishing position. I don’t know if rankings is being actively maintained, but if so it should either be fixed or rankings should not be generated based on this race type.
