Recently switched from a Wahoo Snap with Sterzo Steering to a Wahoo Kickr Shift. Previously when approaching an intersection all the options for turning would appear on the game screen in orange frames at the bottom but now I’m only getting the one course option showing. I can choose left or right from the campanion app on my phone (android) so I can still free ride (I miss the Sterzo) but I can’t see what the options are? Zwift is updated to latest version as is the Kickr
Hello @Mike_Gopperth. Welcome to the forums and congrats on the upgrade! I’m afraid that the Kickr Bike does not support intersection selection via steering (as the Sterzo and Jet Black Steering Block do).
You can still steer using the handlebar buttons on your Kickr Bike Shift to give yourself the best placement on the road, but you’ll need to use Zwift Companion or your keyboard to select intersection choices when doing custom turns. If you want to see all of the turn options available when in an intersection, you can select the current visible option in order to make all options visible.
OK thanks for the prompt reply. Looks like I’ll be needing to get myself a map of Watopia to see what leads where…
OK in case anyone else with the same issue reads this. If I click the one shown option with the mouse pointer at the first intersection then all options are displayed for each intersection for the rest of the ride. Perfect just what I wanted. I can then steer to either option with the companion app
