Spring Classics 2026
Spring challenge 2026. Missing on my front screen was released last night , any can help with this please , thank you for all your help in all sorted now :folded_hands: :smiling_face:
Looks like it’s called ā€œZwift Spring Classicsā€ and it should appear on the Challenges row on the home screen, though you may need to scroll the tiles to the left in order to see it.
I’ve checked from left to right on home screen and it was not there , but do appreciate your help , I was hoping to start the challenge today
I can see it on my home screen, in the Challenges area. It’s a green box.
It does seem to be there for me, running Zwift on a Mac. If you’re on a mobile device or Apple TV I would force quit the app and restart it.
Zwift had given Zwift Insider the incorrect info apparently, Eric posted in the comments recently that’ll be active today (sounds like it is now).
I’m using windows
Thank U I will have a look :blush:
It should have been listed at 12 est. If you logged in at 11:58 you would not have seen it on your Zwift session.
Did 4 different Spring Classic climbs last night. 3 of them are named ā€œZwift - Climb Portal - Mont Saint-Michel in Franceā€ in the Companion App and Strava.
Anyone else seeing this?
Same for me.
Same here
Done the 1st two hills in the Zwift classic challenge………this is a great challenge, the hills are just right, you know you’ve put some effort in but haven’t had the Ven Top tedium…….more challenges like this please Mr Zwift.
Yes, I did four of those climbs earlier. Two of them had the name of the actual climb correctly in the Zwift activity name. Two of them just had the Mont Sant-Michel name that you mention.
just did the koppenberg followed by the cauberg, they are both showing the segment as the koppenberg in strava
I wish that Zwift had a method of chaining these together, rather than having to finish one, end the ride, and then select another.
Ideally, once you select one and exit the Portal, U-Turn, and a menu option would allow you to select another of the Spring Classic climbs.
The Mur d Huy comes up correctly.
The Koppenberg and Paterberg are missing their titles.
There’s a lot of messy overlap on Strava maps. No solution in sight.
I did all eight in a row too. Nice workout.
Impressive…I did the last 5 in a row and decided I am not too good on steep hills. Hurting on the ReDoute
Awesome and agreed.
I did all eight in a row as well this weekend… I will admit I was feeling it (more than) a bit on the last one … a ā€œfunā€ workout. :zany_face:
