I have decided i have had enough of using Zwift with my 15" Laptop screen and i am trying to decide what spec monitor to get
I am no gamer, and the gamers don’t much about Zwift, so can those in the know help please
Seems i need to choose based on budget, panel type (TN, IPS, VA), panel size (thinking 27-32"), refresh rate, resolution and response time. So the question is, which of these specs have a higher impact on the Zwifting experience and should therefore be prioritised. Some shops say refresh rate, others response etc…
Also, am i right in the assumption that a smaller monitor would be better than a larger TV?
(Current spec of laptop is I7-7700 CPU, GTX950M GPU, 16GB ram. I can select Ultra with it, but Zwifalyser recommends High for a higher refresh rate. I don’t want to change the PC out, but one day i will, so i might as well get a monitor with the future in mind)
Thanks in advance
