I have a elite rampa. I succeeded only once to pair it properly with Zwift. All the other times I couldn’t feel the resistance changing when I went up hill.
When you pair the rampa, you can choose; elite power, elite rm, elite trainer, elite this and that. Witch settings do I choose to pair properly and why isn’t my resistance changing?
Thanks Bastiaan. Ik have watched it several times. I even freeze framed it to watch the settings but it didn’t help. I am using ant+. And I have a perfect connection but the resistance doesn’t change whilst cycling on Zwift. I only managed once to succeed on a resistance changing connection.
Hi Aad, I have an Elite Rampa too and have experienced the same issue, I also find that I have too get cadence up to 130 just to hit 300w. Have you managed to resolve the problem ?
Hai Paul, when I use the fec connection everything works properly. It reacts directly to changes in angles etc. I don’t need to hit 130 rpm to hit 300watt. I think that the everage 180w that I achieved is realistic and that’s my reference. I connected to my iPhone via the rm setting and that was less realistic. The resistance was significantly different and the cadence got frequently lost. So I prefer the ant connection with the fec setting and think it’s quite realistic.
I have a RAMPA as well. I have an iPhone 5s with apple adaptors and wahoo ANT+. This works fine with sufferfest.
Swift doesn’t ‘find’ the ‘controllable trainer’ but it does find the cadence source (I have no other other power/cadence sensors). Swift also finds my HR monitor ok.
Any suggestions please -as currently I can only log in and watch from the side of the road rather than ‘RIDE ON’
Ian. With Ant you need to use all the devices (trainer, cadence) in the FEC connection. On your iPhone you can connect via Bluetooth and then connect all the divices at RM. Before you do that you have to reset your rampa by unplugging it.
That’s indeed the right setting for ant+. Well I suppose you need to use the Bluetooth setting then. Can’t help you out with the fec / ant+ setting. May be elite can.
in the beginning everything worked fine . now it doesn’t connect with BT anymore. no idea why… i bought ant ANT+ and it does connect but the wats don’t change automatically anymore. I feel no difference in uphill or downhill… can someone help me out?
