Hello. I have 2 Garmin 2 sensors, 1 speed 1 cadence for about a month now. Everything worked perfect until today, when there is a issue with speed sensor s signal. The battery has been replaced, it s new so that should not be an issue. As soon as I search the sensor in Zwift to be able to go ride, the app finds the sensor, I proceed to the screen where you are supposed to select world and route. As soon as I start spinning the signal from the speed sensor drops and what is shown on screen is that the sensor is connected but there is no signal. I did reconnect the device on bluetooth did restart zwift did try zwift on laptop aswell as on mobile and the same happens. The only thing that is different from some day ago when I last used them is that the game got an update. Any advice?
Related topics
| Topic | Replies | Views | Activity | |
| Sensor Garmin Signal Issue | 27 | 3080 | January 1, 2021 | |
| Losing sensors every time | 1 | 483 | August 31, 2017 | |
| No signal for speed & cadence sensor 2 from Garmin | 25 | 8302 | January 2, 2021 | |
| Mi sensor de velocidad garmin aparece conectado pero sin seƱal | 10 | 2830 | June 21, 2021 | |
| Speed Sensor of Garmin is conected but doesn't sense | 3 | 627 | April 21, 2020 |
