When I try to select a running workout the distance and speed are extremely high and unrealistic… Is this a known issue
Have you set your personal best times for the distances?
The pace for a workout is based on these.
If these are too quick then yes you’ll struggle.
This article will help.
There’s something seriously screwed up with the representation of dates there which suggests a problem with the time management. This is not a widespread issue, there’s something odd or broken about your setup or your computer.
Hi David,
This is what I see so there is something amiss somewhere with your setup. What happens if you do to complete the workout? Does it provide you with equally unrealistic targets or look normal.
I’ve seen the issue with the over populated dates before so not sure the two issues are linked.
Run On!
I haven’t tried to do the workout…
Very weird… Seems to have coincided with the Neokyo update
