Same happened to me today on Richmond. I rode all 3 badges on purpose and not one registered for some reason???
@Keith_Young
Iām looking at your session logs from 2/17. I see you rode 54km in Richmond, but Iām not seeing badge unlocks for any specific routes on this end either. Which three routes did you ride?
I see that youāre on the latest version of the game app for iOS: v1.0.45410, so I expect you should not see any latent issues from running the original Richmond map.
Would you describe what happened during this ride?
- Did you start by selecting a specific route? Do you remember which you chose first?
- Did you manually make any turns off the predetermined route?
- Once you completed the first course (by crossing under a finish arch), did you see a āroute completedā banner across the bottom of the screen?
- Did you save and upload at that point, or did you continue on to routes 2 and 3?
I also had the same issue completing the UCI Worlds course this evening. Selected that course specifically, didnāt make any manual adjustments and kept riding a short while after the completion of the course just to see if there were any delay in the completed banner popping up at the bottom of the screen⦠nothing at all and bummed I wasnāt awarded the achievement
Hi @Anthony_DB
Check if you donāt already have that badge, It look like you did that route on February 8th.
Hi @Gerrie_Delport - I definitely donāt have it
Yep, did the same today. The ā2015 UCI Worldās Courseā 16.3km. I rode up to about 22km but still no badge and I checked before the ride and during the ride to see if I made the mistake. Disappointed again ![]()
The same happened to me yesterday. Did a workout session using 2015 UCI course as a route. Did 24km, more than the 16.3km of the loop.
Also, the day before, I did Highline in NYC, this time not in workout mode. Once gain, no badge, even if I rode 15km, the loop is 10.5km.
In both cases, I expected to receive the badges. Bummer.
I got the badge even though i didnāt ride nor completed that route. Trying to find out how that happened right now
