What does W/KG mean in the left-hand column of the results?
Yes, but on the far left
wkg means you were over power for the category you entered.
You did 3.407 (at 95%) when the limit for cat c is 3.2
You are also a cat B on zwiftpower so even if you were within power for that race you would of likely got a UPG DQ for entering a lower cat.
Stick to the B races and you should be fine.
Hmm… there’s maybe a setup thing gone wrong?
This is what I see for profile and the race description:
ZP profile
Oh yeah that is is setup wrong in zp then i didn’t realise they were using custom cats.
They might sort it themselves otherwise i’d try reach out to contact the organiser
I normally enter Cat B but I entered Cat C because of this. I still got dropped though!
